World's first serial hybrid electric aircraft to fly at Le Bourge
sail4fun
Siemens AG, Diamond Aircraft and EADS are set to present the world's first aircraft with a serial hybrid electric drive system at the Paris Air Show Le Bourget 2011. The two-seater motor glider successfully completed its maiden flight on June 8 at the Wiener Neustadt airfield in Vienna, Austria. The aircraft was built by the three partners to test the hybrid electric drive concept. In the future, the technology, which is intended for later use also in large-scale aircraft, will cut fuel consumption and emissions by 25 percent, compared to today's most efficient aircraft drives.
http://www.siemens.com/press/en/pre.../2011/corporate_communication/axx20110666.htm
Hybrid-elektrisk seilfly, ja, spennende. Diamond driver med mye FoU, blir spennende å se hvordan denne motoren slår an. De har jo vært litt uheldige med bl.a. diesel-varianten som Oslo Flyklubb hadde.
Er flyet beregnet på by-kjøring slik som hybrid-bilene? Kutter motoren når flyet stopper på rødt lys liksom?
