Selv om det _kan_ være to forskjellige feil så vil det vel i denne sammenhengen være mest sansynlig med sekundærskade som følge av at noe inni vingen ble klippet eller kortsluttet.
Selve avstengningen er vel bare en fuel cutoff, men det er kanskje en del motorstyring som vil overvåke at motoren ikke har for høyt temp etc., før den "godkjenner" at motoren stoppes. Kan det være nok at noen slike sensorer mister kontakten før man får problemer med å stoppe? Jeg ville forventet at selve fuel cutoff mekanismen er såpass vital at den har en dobbeltsikring, som kan utløses ved å bruke en form for nødstopp (brannsystem?)
http://www.flightglobal.com/articles/2010/11/06/349412/qantas-a380-likely-lost-engine-disk.htmlThe number two engine on the Qantas Airways A380 involved in Thursday's incident likely lost its engine rotor disk, Qantas general manager David Epstein confirms.
The number three engine on an A380, registration VH-OQC, will be changed after an inspection in Sydney found abnormalities including an oil leak
Another Qantas A380 currently grounded in Los Angeles will have one of its engines changed due to unspecified problems.
The abnormalities in the number three engine of VH-OQC could have potentially led to a repeat of Thursday's incident on QF32, sources say.
The aircraft safely returned to Singapore but with only half of its ailerons working, footage from the incident shows. Additionally, the crew were not able to control the number one engine, leading firefighters to hose down the engine to forcibly shut it down.
Er det bare Singapore Airlines og Qantas som bruker RR?
Hva med Air France, Lufthansa?
Rolls-Royce has concluded that a component failure in the turbine section of a Trent 900 engine fitted to a Qantas Airbus A380 led to the oil fire which destroyed the powerplant in-flight.
In an update to the investigation today the manufacturer states that the failure was "confined to a specific component" in the turbine area
