Hva med EK sitt 380 som sto/står i Canada, ble ikke dette også veldig dyrt?
Ikke i nærheten, og det var bare snakk om en mindre skade
Har du noen prislapp på fixen?
I følge A380production-forumet er det snakk om nesten 800 millioner kroner
For en så stor reparasjon så var ikke dette mye, med tanke på utbytting av wingskin og front spar. :8:All of this added almost 200kg to the aircraft's weight
Earlier reports by Flightglobal Pro had put the additional weight at 200kg, but Airbus clarifies that the actual weight added to the aircraft was far less at 94kg
Qantas Airways and Airbus engineers faced both technical and logistical challenges in restoring its first A380 back to virtually brand-new condition after the aircraft's uncontained engine failure in November 2010.
This week Matt & Andy talk to Richard De Crespigny, the captain of Qantas flight QF32 in which his A380 suffered multiple major failures when one of it's engines exploded. He discusses the incident itself and how he felt afterwards and then gives us some great knowledge and advice about stress, failure management and safety culture. This one isn't just for A320 pilots, in fact, it's not even just for pilots - everyone can learn from this episode.
If that wasn't enough, Richard has also donated two signed copies of his latest book, Fly! for them to give away. He has set a question for you to answer, get it correct and you'll be in with a chance of wining one of these two books.
