Er dette bare i en tidsperiode, eller er det permanent?
Så lenge corona påvirker flytrafikken
Finnair is cancelling all flights to Jyväskylä, Kajaani, Kokkola and Kemi in Finland between 1-30 April.
Finnair is cancelling its flights to Bologna, Stuttgart, Split, Umeå and Venice between 29 March and 30 April.
Finnair will fly to Mariehamn with triangle flights via Bromma.
Finnair is reducing frequencies to the following destinations between 29 March and 30 April:h
Gothenburg flown with 14 weekly frequencies instead of the normal 27 weekly frequencies.
Copenhagen flown with 27 weekly frequencies (normally 39)
Stockholm Bromma flown with 17 weekly frequencies (normally 28)
Stockholm Arlanda flown with 45 weekly frequencies (normally 55)
Moscow flown with 21 weekly frequencies (normally 28)
Tallinn flown with 53 weekly frequencies (normally 58)
Barcelona flown with 14 weekly frequencies (normally 21)
Hamburg flown with 14 weekly frequencies (normally 21)
Berlin flown with 21 weekly frequencies (normally 28)
Warsaw flown with 14 weekly frequencies (normally 21)
Brussels flown with 19 weekly frequencies (normally 24)
Tromso flown with 2 weekly frequencies (normally 3)
Trondheim flown with 4 weekly frequencies (normally 5)
Bergen is flown with 6 weekly frequencies (normally 7)
Vaasa flown with 20 weekly frequencies (normally 33)
Oulu flown with 54 weekly frequencies (normally 66)
Joensuu flown with 20 weekly frequencies (normally 31)
Kuopio flown with 32 weekly frequencies (normally 43)
Turku flown with 22 weekly frequencies (normally 33)
Finnair will fly to St Petersburg and to Vilnius with ATR aircraft instead of Embraer 190 aircraft in April.
Flights that were scheduled to be operated with an Airbus 350 to Brussels will be operated with Airbus 321 aircraft in April, as is one of the two daily wide-body frequencies between Helsinki and London.
På grunn av COVID-19-situasjonen forbereder Norwegian kanselleringer av rundt 3000 av selskapets flygninger fra midten av mars til midten av juni. Det utgjør cirka 15 prosent av den totale kapasiteten for perioden. Norwegian innfører også en rekke andre tiltak, inkludert permitteringer av et betydelig antall ansatte.
Delta Air Lines takes measures to address the financial impact; reduces capacity by 15%
Ego igjen...
Washington med SAS om seks dager.. Hmm, Vi hadde vel hørt noe nå?
I en intern e-post sendt ut til de ansatte, levner finansdirektør Torbjørn Wist liten tvil om at harde tiltak er nødvendig for å få SAS gjennom krisen som corona-viruset har skapt.
«For å kompensere for den skarpe nedgangen i inntekter har vi et presserende behov for å kutte kostnader og bevare kontanter», skriver Wist.
Austrian kutter nå opptil 50% av programmet. Bla. vil OSL forsvinne fra slutten av mars til minst 24.april. Andre destinasjoner er Birmingham, Manchester, Lyon, Barcelona, Firenze, Leipzig, Nürnberg, Salzburg, Göteborg, Krakow, Sibiu, Vilnius, Minsk og Sankt Petersburg.
Hele Lufthansa Gruppen annonserte nettopp innstilling av 23.000 flighter mellom 29 mars og 24 april. Det må vel være ganske mange prosent?
